Does anyone know if there is a way to either copy offline areas from one map to another or save them with the map? I am creating multiple maps for the same area for field workers and do not want to recreate the same offline areas for each map since there are quite a few. I've tried copying the map in Field Maps but the offline areas don't copy over.
@vaishalikulkarni00 there is no way to directly copy offline areas from one map to another at this time. However, if you are familiar with Python, you can create map areas with the ArcGIS API for Python. We have an example script that might help you get started - Create Offline Areas from Feature Layer. This script uses feature geometries from a feature layer to create map areas, but could be modified to use map areas from one map as the input geometries/extents to recreate these areas for other maps.
