Can I use html in a constraint message? I'm using Survey123 Connect 3.18.123.
I'm using an unordered list in html in my constraint message. Using the field app, this has always worked. Today, I tested the survey in a web browser and I see the html code is displayed. I'm guessing that the html is displayed properly in the field app, but it's not a supported feature.
I've attached an XLSForm that demonstrates the issue, but I'm suspect that someone will tell me that I shouldn't be using html in a constraint message. If that's true, it would be nice to have documentation explicitly state that constraint messages do not support html. Since it worked in the field app, I thought it was supported.
I read this post: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-quick-guide-to/ba-p/1101322
Thanks, Chuck
