i'd like to convert an existing SHP file to SVG with included id attributes to identify each polygon (path) in the exported SVG. However, when exported, only the <g> tag that includes all polygons in the SVG is assigned an id attribute equal to the SHP name. I would need each <path> element to have an id attribute equal to the id of the polygon from shapefile (well, from it's attribute table).
Step by step replication (version 3.1.2):
Open new project, load a single shapefile, no basemaps. Go to Share, Export Map. Choose SVG under File Type, set location and name, leave Output as image unchecked. Export. Inspect SVG in notepad to see if each <path> element has id assigned.
What I need to see in SVG file is something like:
<svg height="400" width="450">
<path id="Poly1" d="M 100 350 l 150 -300" stroke="red"
stroke-width="3" fill="none" />
<path id="Poly2" d="M 250 50 l 150 300" stroke="red"
<path id="Poly3" d="M 175 200 l 150 0" stroke="green" stroke-width="3"
fill="none" />
</svg>
what I instead get is something like this:
<g id="ShpName">
<path d="M 100 350 l 150 -300" stroke="red"
<path d="M 250 50 l 150 300" stroke="red"
<path d="M 175 200 l 150 0" stroke="green" stroke-width="3"
fill="none" />
</g>
</svg>
The help page on exporting to svg here mentions "Options specific to vector data, such as Layers and attributes...", but I cannot find these options anywhere.
A workaround might be to create a separate SHP for each polygon in original SHP and export the map - each SHP would then be it's own <g> element. But I would prefer a more elegant solution if anyone has any idea how to acheive this.
Best regards,
T
