Hi community,
I'm currently working to have available demonstration environments for Utility Network in our ArcGIS Enterprise deployment for Communications, Electric, Water, and Gas domains. The goal is to have, for each domain, a deployment of the respective Utility Network Foundation model, containing both the UN schema for that domain and the companion data from the Naperville data sample.
Indeed, I was able to apply the Asset Package with companion data for Electric, Water, and Gas, but I'm facing some challenges with the Communications Utility Network Foundation. What I did up to now was:
1. Tried to copy and paste the feature dataset from the sample UN contained in the Communications Utility Foundation Model. It did fail as discussed here (see the message box screenshot with the error details below).
2. Went through the Export/Stage/Apply:
2.1 Executed "Export Asset Package" from the existing fgdb UN - it works
2.2 Executed "Stage Utility Network" on the enterprise geodatabase - it works
2.3 Executed "Apply Asset Package" using the gdb exported in step 2.1(Structures and Communications domain network selected) and the target UN generated in step 2.2 ("Load Data" and "Calculate Spatial Index and Analyze" options were selected) - it fails (failure message in the screenshot below)
I'm interested to know if anyone has additional ideas on how to meet the deployment goal. Since I'm trying to keep everything as simple and straightforward as possible.
Here are the details of my execution environment:
ArcGIS Enterprise 11.1
Enterprise Geodatabase is SQLServer
ArcGIS Pro 3.12
Communications Utility Network Foundation v1.4
