I have below questions regarding Run GP Service step in ArcGIS Workflow Manager v10.9.1.
Highly appreciate your response.
Thank you.
It’s unfortunate that no one has answered this question yet—I have similar concerns as you.
I have observed that when the GP Service is configured as Asynchronous, the step remains in a running state even after the GP task has completed its execution. However, when configured as Synchronous, I encounter a timeout issue in the logs (Submitted job failed: Request timeout to ---- after 120000 ms).
Additionally, with the Synchronous configuration, I am unable to track the GP Task status from Server Manager → Site → Jobs.
If your task completes within a few seconds, using the Synchronous type is recommended. However, for longer-running tasks, the recommended GP Service type for the Run GP Service Step is Asynchronous. I would suggest conducting further research to determine the best approach based on your specific use case.
