In a scenario where ArcGIS Portal was deployed in HA with an external ELB and assuming that both machines were named:
- Machine A (Primary)
- Machine B (Standby)
When I query Portal logs from the REST endpoint, why does it show entries for both Machine A and Machine B executing user actions like when users publish a service despite Machine A acting as the primary. Shouldn't only Machine A do the bulk of the work?
Is this a normal behavior or has it got something to do with the ELB routing to the standby machine instead?
I understand both machines are capable of processing requests and acts as if they're active-active in HA --->Re: Activ-Activ "Portal for ArcGIS" in HA deployme... - Esri Community
