I have a Web App Builder Map with Smart Editor Widget configured.
The hosted feature layer in the map is a point layer. In the point layer, there are points that are stacked on top of each other, and some with single points.
When we select one of the stacked points, Smart Editor selects all of the points that are stacked on top of each other. We have "Edit Geometry" enabled by default, and when we try to edit the geometry of one of these stacked points, we cannot. The stacked point selection turns yellow - see attachment 1. However when we select single points, the selection turns blue and we can edit the geometry - see attachment 2.
Question 1: is there a setting we can choose to unselect points in the stacked selection, like "remove from selection" or "unselect"?
Question 2: is there an overall setting that we are missing in the General Settings tab of Smart Editor?
thank you for your help.
@AlixVezina
@ChrisUnderwood
@Wei_Ying
