Simple question which i can’t seem to find the answer for. I want to build a survey on top of an existing feature service and want to use S123 to create sequential sub records for the existing records. I created a survey using Connect. How do you set up a “Select_one” field in the XLSForm to look up values in a field in the existing record set of the feature service? Just the lookup part, I think I can take it from there with the repeat.
