I want to allow my Field Maps users to view their location. Meaning as they walk or drive a trail (line) will be visible that shows the route they used. I have enabled Location Tracking for Field Maps. I tested it successfully in Field Maps. But what is the difference if I use ArcGIS Tracker? is ArcGIS Tracker a different app than Field Maps?
Worth reading through this - it looks like Tracker functionality is being rolled into Field Maps.
Deprecation Notice for Explorer, Collector, and Tracker (esri.com)
Tracker will eventually be fully replaced by FieldMaps so that's what I'd suggest you should use.
Hello, I need to do something similar. Did you end up using Tracker or Fieldmaps? Thanks
