Hello - i have a new hosted feature that was initially only created through a new Survey123 survey (created in S123 Connect). I am trying to use that feature layer within a web map that will then be used for editing in Field Maps, but for some reason I cannot tap on the point in Field Maps to open up the attributes and go to edit. Nothing happens - it is as if the point feature is unresponsive in Field Maps.
Is this some sort of bug or is this not a capability to use the hosted features that are created from Survey123 surveys in Field Maps?
