Best regards.
I am using the coordinate conversion widget.
You may know that the widget has a capture mode that takes the coordinate when you click on the map. I need to implement some logic when that action is performed. Specifically, I need to display the coordinates in a <span> tag right after the map is clicked. Only at that time I need to see the coordinates, does anyone know how I can achieve that?
