I’m doing a final project for my fundamentals of GIS. The topic I’ve chosen is to compare states by their firearm regulations and see if the gun violence in those states is reduced. I’m also looking to see if there is any other correlation to gun violence across the country. I’ve found so much data on the subject. The question I have is what kind of raster data can I used for this? I only need to use it for one map but I’m hung up on how or what kind would assist my project.
I would also recommend reaching out to the professor first! They will be able to give a recommendation on some next steps to take.
Here is a couple of follow-up thoughts -
I'm a little confused on the question! Do you already have data for your project and you're looking specifically for raster data?
One thing I sometimes recommend on GIS projects - sometimes less is more with time sensitive projects! More data does not always mean more accuracy or more impact, it just means that it takes more effort to finish the project. So depending on what your thesis statement is, you may not even need the raster data!
I hope that helps - good luck with your project!
As an instructor, i would suggest reaching out to your professor for assistance. There are some fundamental constructs you are missing, and I'm certain that your instructor would be the best resource for you.
Good luck!
