I have set up a survey using one of the built in themes available using Survey123 on the web. When I preview the survey, it displays with the theme. However, after saving and publishing, the live survey shows up with only a plain white background. I have tried using other available themes and they all result in the same issue. Has anybody else experienced this and found a solution?
