I need help. I have a rogue map frame. Arc Pro 3.1.2 - I have two layouts. Each have two map frames.
It's laid out as a plan/profile layout. upper frame is a map view - lower frame is a cad .dwg -
I have two layouts - only 1 with the issue. the issue is, no matter how I set the map frame view - if I save and exit - then reopen the project. The 2nd layout - cad frame - reverts back to a different scale and position from what was set. if I reactivate that frame, I can only pan the view so far and it stops as if it hit a wall. I'm assuming it reached an extent - however the extents are set to extent of all data in layers. If I somehow manage to get it repositioned and saved or go in and manually change the extent - as soon as I let off of the extent field - the numbers revert back. I've deleted the frame and completely recreated it - saved the project, exit out and come back - and it reverts back. It's only on layout 2. layout 1 seems unaffected. I cannot for the life of me figure out what is going on with this one layout. all other projects are fine and the other layout in this project is fine -
