Hi all,
I'm using 3.1.1. I have this setting changed to default to the Select Tool, as shown below. Here's my workflow - using the Select Arrow
I select a polygon. Then I click on Map ribbon - Select By Location - put in parameters, hit Ok.
Bam, I'm back to the Explore tool.
I'm not using an Edit tool that I have to close manually to trigger the Select Arrow as default.
I would like my default tool to be the Select Arrow. Always. I don't use the Explore Tool. It's slow and cumbersome.
Thank you!
https://pro.arcgis.com/en/pro-app/latest/help/editing/productivity-options-for-editing.htm
