Hello
I am with Arcgis Pro 2.9. I am using data reviewer for QA/QC the geodatabase to check the errors in it. I created a rule using attribute rule ready-to-use rules to check for duplicated data. Then a use error inspector is to evaluate data according to this rule. the result of the evaluation is an error the error says "Evaluate rules__ Edit operation failed the row contains a bad value. I attached an image to show the error message. Why does this message appear? and how can i fix it?
Thank you in Advance.
In general, that error usually means a field in the data is being edited with an invalid value. For example, if you try to insert a 36-character string into a field with a max of 35 characters you'll get that error.
For Reviewer-based validation attribute rules, you may want to verify that the Name and Description properties of your rules do not exceed 64/256 characters in length, respectively.
