Good morning
I am trying to join a polygon feature class to a standalone table. Both objects are within a file geodatabase. Using ArcGIS Pro 3.0.2.
Using GeoAnalystics Join Features tool, my target layer is a polygon layer with a text field length of 50. The join table also has the same text field length of 50. I'm executing a one-to-many join operation.
The issue is the output object turns all text fields into a length text field of 1,048,758. This seems like a relatively simple operation. I've tried this in SQL and the local GDB. I've cut out all fields to just the Join fields to try and isolate any other issues, and I always get the same result.
Why is this happening and how can I prevent it? I'm including screenshots to help illustrate the issue.
Help me ESRI Community, you're my only Hope! (Happy May 4th!!)
