Hello, I am creating an electric utility network inside my organization. I followed steps from documentation: Get started with the Electric Distribution Utility Network Configuration—Get Started | ArcGIS for Electric and everything is configured as it should be. I am using SQL Server 2014 database. I am trying to 'Apply an asset package' and getting errors.
Error executing function.
The utility network association already exists.
Failed to execute (ImportAssociations).
EXCEPTION
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\common\wrappers.py", line 90, in wrapper
return func(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\gptools\tools.py", line 300, in run
share.schema_apply()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\utils\shared_validation.py", line 504, in schema_apply
return self.apply()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\utils\shared_validation.py", line 450, in apply
result = func(**kwargs)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 2051, in ImportAssociations
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 2048, in ImportAssociations
retval = convertArcObjectToPythonObject(gp.ImportAssociations_un(*gp_fixargs((in_utility_network, association_type, csv_file), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
Failed to execute (AssetPackageToUtilityNetwork).
Could anyone tell me what am I doing wrong?
