It was possible in the Collector App to show the newest value from a related table in a pop-up. Unfortunately it is not possible in Field Maps anymore. It means that people in the Field need to scroll all the way down to find the newest value. Working in the Field with cold fingers and scrolling doesn't work well. I hope this can be repaired.
Hi - It is possible to do this by creating a view of your related table and setting it to just show the most recent record. This is described very well by Eric Wagner in the following YouTube video. See about 6:40 mins into the video: https://www.youtube.com/watch?v=gqC-EEw3nxY
I don't know if it is possible to do this directly in FieldMaps however the result will show in your map when viewed in FieldMaps
David 🙂
Hi @JolanHarbrecht ,
You can access related records from a feature using Arcade and add values from a field to the feature's popup. The following Arcade should get you started:
//call related table named Inspections var related = FeatureSetByRelationshipName($feature, "Inspections") //order by DateField var ordered_related = OrderBy(related, "DateField DESC") //get the first feautre from the ordered feature set var latest_inspection = First(ordered_related) //get the value from the field of interest var value = latest_inspection.valueField return value
I hope this helps.
Chris
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
