I have a script that reads my AGOL User store and finds users that are about to be deactivated. Although when I run it I get this:
ERROR:
Matplotlib created a temporary config/cache directory at C:\Users\J~1.KAP\AppData\Local\Temp\matplotlib-i0q8mino because the default path (H:\.matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
I am not sure what is trying to use Matplotlib in my script nor how to fix this... Any ideas?
from arcgis.gis import GIS
import arcgis
import csv
import time
from datetime import date, datetime, timedelta
agol_username = 'xyz'
agol_password = 'xyz'
output_csv = r'C:\Users\xyz\Desktop\GIS_projects\AGOL_Python\UsersAboutToExpire.csv'
search_user = '*'
gis = GIS('https://xyz.maps.arcgis.com', agol_username, agol_password)
user_list = gis.users.search(query=search_user, max_users=2000)
roles = gis.users.roles.all()
rol_ids = {role.role_id: role.name for role in roles}
output = []
def main():
with open(output_csv, 'w', encoding='utf-8') as file:
csvfile = csv.writer(file, delimiter=',', lineterminator='\n')
csvfile.writerow(["username",
"email",
"roleID",
"level",
"disabled",
"role",
"licenseType",
"lastLogin",
"daysSince"
counter = 0
for user in user_list:
lastLogintime = user.lastLogin/1000
lastLoginTimeConvert = (datetime.utcfromtimestamp(lastLogintime).strftime('%Y-%m-%d %H:%M:%S'))
format = '%Y-%m-%d %H:%M:%S'
lastLoginDate = datetime.strptime(lastLoginTimeConvert, format)
lastLoginDATE = datetime.now() - lastLoginDate
lastLoginDAYS = lastLoginDATE.days
varDisabvled = user.disabled
#if lastLoginDAYS > 80:
if lastLoginDAYS in range(80,90):
if varDisabvled == False:
try:
varusername = user.username
varemail = user.email
varRoleID = rol_ids[user.roleId]
varlevel = user.level
vardisabledValue = user.disabled
varrole = user.role
varlicenceType = user.userLicenseTypeId
varLastLogin = lastLoginDate
varLastLoginDays = lastLoginDAYS
z = (varusername if isinstance(varusername, list) else [varusername]) + [varemail] + [varRoleID] + [varlevel] + [vardisabledValue] + [varrole] + [varlicenceType] + [varLastLogin] + [varLastLoginDays]
output.append(z)
counter += 1
csvfile.writerow([varusername,
varemail,
varRoleID,
varlevel,
vardisabledValue,
varrole,
varlicenceType,
varLastLogin,
varLastLoginDays
except KeyError as e:
print(user.username, e)
if __name__ == '__main__':
main()
