I use the JOIN command quite a bit to add data to ZIP layers. So, I do a JOIN on the ZIP field. Does JOIN convert types to match? E.g. if I JOIN on ZIP that is integer and the other layer ZIP is a string (as it should be) will the JOIN work?
I got this question from a colleague and I simply don't know. I haven't run into it.
The Living Atlas ZIP layer the ZIP filed as a string, and I usually type mine as string when upload data.
Has anybody done this experiment? Is there a known spec on the JOIN command, e.g. would integer = 2 match a float = 2?
I'd love to see a doc or answer to this, just in case...
Thank You.
