I'm using Visual Studio with ArcGIS Pro SDK my current version of ArcGIS Pro is 3.1.0, A co-worker has created a python scripted that took 77 mxd's and converted them to aprx files, each one has an existing map in the Catalog pane associated with the map, but when you open the aprx there is no map pane view opened. I was looking in the configuration of the ArcGIS Pro SDK and it seems like there should be a method to have the MVVM look to see if there is a map associated with the project and open that map in a map pane view. I have narrowed down the location to be the ViewModel for the sdk configuration is where I should add an ICommand Interface or maybe another piece of code that adds this function to the "browse to project" functionality of the configuration, but I haven't been able to find the documentation on how that command is called into the model view. I was hoping someone could give me a little direction on if I am indeed correct or if there is another function / method I should be considering.
so this article goes into what I am trying to do but the I am not trying to use an OnClick method but use the View Model in the configuration to always check the project for a Map and open it up on startup of the project.
https://community.esri.com/t5/arcgis-pro-sdk-questions/open-an-existing-map/td-p/791296
