Hello all!
I'm trying to create map series with ArcGIS Pro basic 3.1 and postgresql database 13.5 (postgis 3.1.4).
I made all the steps following the online procedure, and no errors/messages were returned but in the "contents" tab no map series appeared.
I exported the same data in a feature class in a local esri geodatabase, I made all the same steps and it works perfectly (but I need to use postgresql).
Online I didn't find any clues that this issue could be linked to the licence or to a particular extension needed.
Is it and expected behaviour or is this a bug? Any suggestions?
Thank you
Cesare
