I recently updated Survey123 Connect to version 3.17.54. Previously, fields were only required in repeat sections if you wanted to use that form. Now, however, it appears that the fields are required regardless of whether or not you have data in that section/repeat form (we have a large form with many groups and repeats). Is there a way to make these fields only required if you have data in the repeat section?
Secondly, I am having issues with conditional requirements using an answer from a select_one_from_file. It will not allow me to use this field in the select formula in the required field. Is there a way around this? Any help is very much appreciated!
thank you
