Hello, Everyone
I am in the middle of installing ArcGIS Enterprise that will support 3D applications based on Point Cloud data. My question is where to store ArcGIS data store tile cache (data directories)? Could I store it on (NAS storage) or I have to store it on local drive? given that the Point Cloud data will be (TBs) in size.
@BillFoxI have only Image Hosting server (Image server license). Is it a must to configure the Image sever with Image Hosting and Raster Analytics at the same time so that I publish scene layers from LAS files?
@Scott_Tansley Thanks for this helpful information, I do appreciate your support
Do you have ArcGIS Image Server too? Image Hosting and Raster Analytics?
Hi. You can only use local disk.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/create-data-store.htm#:~:text=Keep%20data%20store%20files%20on%20the%20same%20machine%20where%20you%20install%20ArcGIS%20Data%20Store.
You should also consider this advice:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/install-data-store.htm#:~:text=Esri%20recommends%20that%20each%20type%20of%20data%20store%20run%20on%20a%20different%20machine%2C%20and%20that%20your%20ArcGIS%20Server%20sites%20run%20on%20separate%20machines%20than%20the%20data%20stores%20so%20that%20they%20don%27t%20compete%20for%20memory%20and%20other%20resources
Effectively you could use premium disk (performance) on your base deployment/hosting server, and for the tile cache host you could potentially use lower grade disk to save on budget without compromising performance elsewhere in the system.
