Hi!
I have following workflow:
- Put a transparent foil on a paper map and draw some primitives
- Scan to image
- make background (white, created by the scanner) transparent (using gimp, photoshop or similar)
- Use ArcGIS Pro and georeference the image (see https://learn.arcgis.com/de/projects/georeference-imagery-in-arcgis-pro/)
Unfortunately, when i save a new file (geotiff), the transparency is lost....
I recognize this when the exported file is automically added to the map.
Same behaviour, when my application (based on ArcGIS runtime for qt, V100.8) is reading the exported file.
Can anyone help me?
Thanks in advace!
