Switched to ARCPRO 3.0 at work and have found that it crashes for no apparent reason. We use a lot of imagery at work and having Pro crash during a project is getting infuriating. Is there any way that I can establish why it is crashing (a fault log for example) so that I can go to my database manager to try to rectify this?
if possible try uploading the imagery to a file geodatabase and see if that helps. It could be the way you are accessing the imagery causing it to crash.
I have ArcGIS Pro 3.0.1 and use mosaics created from raster datasets as a base map and mine works fine. How is your imagery hosted?
For example is it hosted in a file geodatabase? Or a network server?
Apologies for not being clearer. The imagery we use is on a server. We have not changed the way we work and everything was fine with version 2.8. I cannot tie the reason down to one specific example as to what i am doing when it decides that it has had enough and quits on me.
Can you provide more context and details as @SLouq mentions?
