Hi All,
I'm having issues building a valid SQL expression I keep getting an invalid syntax, no matter what I try.
I'm using Pro version 3.0.3
I have a filed called "OID_" in a point Feature class
the error is to do with the sql_expression
File "<string>", line 1
OID_ >= 1001 AND OID_ <= 2000
SyntaxError: invalid syntaxWhat am I missing here?
Below is a snippet of my code:
field_to_search = param2 #"OID_"
field_to_update = param3 #"test"
field_with_values = param4 #"T_500"
# Define a list of search and copy ranges
search_ranges = [(i, i+999) for i in range(1001, 998002, 1000)]
copy_ranges = [(i+1, i+1000) for i in range(1001, 998001, 1000)]
# Create a search cursor to loop through the feature class
with arcpy.da.UpdateCursor(fc, [field_to_search, field_to_update, field_with_values]) as cursor:
# Loop through each range of rows
for search_range, copy_range in zip(search_ranges, copy_ranges):
# Build a SQL expression to select the rows to update
sql_expression = 'OID_ >= {} AND OID_ <= {}'.format(search_range[0], search_range[1])
# Select the rows to update
selected_rows = [row for row in cursor if eval(sql_expression)]
# Loop through the selected rows
for i, row in enumerate(selected_rows, start=1):
# Calculate the index for the row to copy from
copy_index = row[0] + 1
if copy_index >= copy_range[0] and copy_index <= copy_range[1]:
# Select the row to copy from
cursor_copy = arcpy.da.SearchCursor(fc, field_with_values, "OID_ = {}".format(copy_index))
for row_copy in cursor_copy:
# Update the field with the value from the other field
row[1] = row_copy[0]
cursor.updateRow(row)
break
del cursor_copy
# Reset the cursor to the first row before starting the next range
cursor.reset()
FYI this is the other versions I have tried:
sql_expression = "{} >= {} AND {} <= {}".format(arcpy.AddFieldDelimiters(fc, field_to_search), int(search_range[0]), int(search_range[1]), arcpy.AddFieldDelimiters(fc, field_to_search))
sql_expression = f"{field_to_search} >= {int(search_range[0])} AND {field_to_search} <= {int(search_range[1])}"
sql_expression = '{} >= {} AND {} <= {}'.format(field_to_search, str(search_range[0]), field_to_search, str(search_range[1]))
sql_expression = "'{}' >= {} AND '{}' <= {}".format(field_to_search, search_range[0], field_to_search, search_range[1])
sql_expression = "{} >= {} AND {} <= {}".format(arcpy.AddFieldDelimiters(fc, field_to_search), search_range[0], arcpy.AddFieldDelimiters(fc, field_to_search), search_range[1]) # Select the rows to update selected_rows = [row for row in cursor if eval(sql_expression)]
