trying to update hosted feature on ArcGIS Enterprise 10.8.1+ from local GDB
this is the Exception
Exception: 'appendUploadFormat' must be one of the following: shapefile, geojson, csv, featureCollection, excel.
in the API working with fgdb is option ,
this is the function i use for the update what am i missing ?
def append_and_update(agriplots,gdb, url,username,password):
gis = GIS(url = url, username=username, password=password)
layer_for_update = FeatureLayer(agriplots,gis)
print("Uploading File Geodatabase")
fgd_properties={'title':"Temp GDB deleted at the end", 'tags':'temp file geodatabase', 'type':'File Geodatabase'}
gdb_item = gis.content.add(item_properties=fgd_properties, data=gdb + ".zip")
print("updating... ")
result = layer_for_update.append(item_id=gdb_item.id, upload_format="filegdb",source_table_name='AP_WGS84',return_messages=True)
print(result)
delete_result = gdb_item.delete()
print(delete_result)
