It would be great to have more granularity when trying to set the extent of the map in the map viewer.The current set up for the zoom levels has too much of a gap. It would be great if Esri could add more pre-configured zoom levels in between the existing ones.
There is a similar idea for ArcGIS Enterprise: Solved: Re: Finer grained control over web map extent? - Esri Community Although it is marked as solved, unfortunately, it does not have a proper solution.
Yes please! We get complaints from users. Even non-technical people are very used to navigating online map software at this point and having a fine level of zoom control is pretty standard.
This really is an essential idea. I frequently use a particular administrative area as a starting display and it's impossible to get it to show at an ideal zoom level - one of AGOL's zoom levels is too far out and the next one is too close in and bits get cut off the edge.
I have to say, I also find the usage of 'State', 'Neighbourhood' etc to be a peculiarly USA-centric approach to user experience for a company that seems to pride itself as a global leader in GIS. States etc mean absolutely nothing where I am.
Yes, please.
It is really difficult to set the correct extent of web maps, and, by extension, web apps, with the current set up.
There doesn't seem to be a way to set things to common standards, for example 1:100,000 or 1:24,000.
Neither is there a way to tell the current scale. Quite frankly, "States" and "Neighborhood" mean nothing to me.
Part of this as well is trying to zoom in. I can either go waaaay too close or waaaay too far, and what I really need is exactly between those two options. I would love to just say "Okay, give me 1:550,000 and we'll see how that looks" instead of settling for a zoom level that isn't what I want.
For example, I'm trying to save a map to show all of Wyoming. I can either save it at a scale that shows me 80% of the state, or one that gives me 100% of the state plus 100+ miles in any given direction. I need something between these two levels.
Please let us set the scale in the way that we've been doing it in ArcMap and Pro for years.
Thank you for unearthing this previously "Solved" idea. This is absolutely crucial.
If find it exceedingly bizarre that Map Viewer does not let the owner of a map set bookmark scales by typing in a number. This only gives the user the clumsy control afforded by mouse or touchpad dragging. it's a glaring weakness.
Connectez-vous pour publier, suivre le contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
