I'm having a horrible time trying to publish script tools in ArcGIS Pro to ArcGIS Server. Currently I have a script tool that does pretty much nothing. It runs through cleanly in Pro but when I try to share it as a Web Tool I can never get past the Analyze which appears to be required. It would be great if that could be circumvented in some way because it seems to be the biggest computer Karen ever invented. Please let me worry if my script is going to function or not!
Anyway, my script tool hangs at Analyze. The script does nothing! I've been publishing script tools to Server from Desktop for a decade!
To make matters worse, when I get these script tools to Analyze, I publish the simple one and then go in to the services folder and replace the script tool with the real python script. The real script will never ever analyze!
import arcpy, os, time, traceback, sys
def main():
try:
#get the oids parameter
state_abbrv = arcpy.GetParameterAsText(0)
cnty_name = arcpy.GetParameterAsText(1)
uscong_dist = arcpy.GetParameterAsText(2)
program = arcpy.GetParameterAsText(3)
scr_ws = arcpy.env.scratchWorkspace
arcpy.env.parallelProcessingFactor = "25%"
# map documents
inFldr = r"\\drive\share\folder"
# PDF files
nowDt = time.localtime(time.time())
sdt = time.strftime("_%Y%m%d_%H%M%S", nowDt)
outFilePdf = os.path.join(scr_ws,"Summary_Rpt" + sdt + ".pdf")
pdfDoc = arcpy.mp.PDFDocumentCreate(outFilePdf)
pg = os.path.join(inFldr,"publish.pdf")
pdfDoc.appendPages(pg)
pdfDoc.saveAndClose()
del pdfDoc
arcpy.AddMessage("PDF completed")
#Set the output parameter
arcpy.SetParameter(4, outFilePdf)
arcpy.SetParameter(5, outFilePdf)
return
except arcpy.ExecuteError:
# Get the tool error messages
msgs = arcpy.GetMessages(2)
# Return tool error messages for use with a script tool
arcpy.AddError(msgs)
return
except:
# Get the traceback object
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
# Concatenate information together concerning the error into a message string
pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
msgs = "arcpy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
# Return python error messages for use in script tool or Python Window
arcpy.AddError(pymsg)
return
#Main part of the script
if __name__ == '__main__':
main()
arcpy.AddMessage("Export completed")
