Greetings,
My Environment: ArcSDE 10.1, RHEL 6, Oracle 11g
We changed a password on an Oracle schema, but apparently we have some rogue SDE clients - probably old ArcGIS map services or map documents somewhere - attempting to connect with the old password. SDE is causing Oracle to lock out the schema because of the rapidfire attempts to connect with the bad password.
I found that Oracle audit always trace SDE server name as it is unable to see the underneath connections of SDE application server.
Is there any way to detect where the bad login attempts are coming from?
