Has anyone ever had trouble with converting labels to annotation and the anno attribute table has no records in it. The first one I made was fine but everyone since then has been wrong. Everything is in the same geodatabase. Labels are labeled how I want them. I tried going out of Pro and then back in. Nothing. I've tried moving things to a new geodatabase. Nothing. Any ideas on what might be going on???
Thanks!! I know that part. All my labels are on when I convert.
Michelle Couden
Cartographer
Certified GIS Analyst
TPP Wellness Contact
Transportation Planning and Programming
Traffic Analysis Section
(512)486-5136
Watch for Cyclists!
HI Michelle,
I've never heard of an issue like this for converting labels to annotation.
What I'm thinking may be happening from your description is that you label, convert labels to annotation and then the labels aren't turned back on for the next conversion run so nothing actually gets converted into the feature class.
To check this, click on the Label view tab in the Contents pane and see if the layers are checked on for labeling. If they're not, check them and test to see if that resolves it.
Please let me know what happens.
thanks
Wendy
I’m limited on that. I work for Texas Department of Transportation. They more than likely do not have the newest version yet to download. IT worked the first time I did it.
I would recommend upgrading to the latest version of ArcGIS Pro (2.3.1) and re-testing. I know that we have improved the annotation experience in the last few releases.
