I have a script tool in Pro 2.9.5 that uses arcpy.management.ReconcileVersions. The input for the workspace is supposed to be a feature layer, for branch versioning, which we are using. When I run the script tool, it succeeds and does exactly what I want.
Explanation of the input_database below (arcpy.management.ReconcileVersions(input_database....):
My code is getting the url of the item, which ends up being the feature service url. Again, works great in Pro. When I publish the tool to our federated server as a Web Tool, it fails, and says the workspace type is not correct.
Full error in GP tool when run at REST service:
ReconcileVersions retval = convertArcObjectToPythonObject(gp.ReconcileVersions_management(*gp_fixargs((input_database, reconcile_mode, target_version, edit_versions, acquire_locks, abort_if_conflicts, conflict_definition, conflict_resolution, with_post, with_delete, out_log, proceed_if_conflicts_not_reviewed, reconcile_checkout_versions), True))) File "E:\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda> return lambda *args: val(*gp_fixargs(args, True)) arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. ERROR 000837: The workspace is not the correct workspace type. Failed to execute (ReconcileVersions).
I have tried everything I can think of, including using the .sde workspace and nothing seems to work. Any ideas?!
