Hello! I'm wondering if there's a way to connect an external GPS with some other protocol than bluetooth? I'll explain my goal so the question is easier to answer.
I want to connect a drone to Field Maps, so that I can see it on the map and draw lines/edit the maps using the drones position. As I understand it, most drones GPS's doesn't work externally but i'm thinking that you could get a small external GPS and attach it to the drone, which can connect to Field Maps.
I've used a precise GPS, but that connects via bluetooth which wont cover the range between GPS and iPad.
Could you potentionally use one of those small gps trackers for vehicles and somehow pair that with Field Maps?
Cheers!
