I would like to try and make some modifications to a couple of domains in our water utility network, but I'm having some problems.
Currently we have a Boolean domain for the operable field of our Water Device feature class. I would like to have Maintenance Needed as an additional option. I do not want to add it to the Boolean domain, since then it is no longer boolean and that domain might be used in other fields as well. I created a new domain, but I am not able to remove or assign the domain from the field. Or, I should say it looks as if the new domain is assigned, but it still only gives True and False as options.
Similarly, I noticed that the gnss fix type field was not assigned a domain for our Water Junctions. It looks like I added it, but there is no drop down menu.
For our fire hydrants I noticed one of the fire districts was misspelled. I tried to edit that domain for the fire district field, but was unable to.
I have been able to add additional codes/descriptions to other domains that we use.
So, is changing the domain assigned to a field or changing the existing description not allowed for any field in the utility network? I understand it is not for Asset Type, but none of these are for that field.
Thanks in advance!
