Hi All,
I am relatively new to python. I am trying to convert km* files into layers in a GDB but I am getting the following error: ERROR 000732: Input KML File: Dataset 413 REDD Project.kml does not exist or is not supported
Failed to execute (KMLToLayer).
Any comments would be highly appreciated
import arcpy
import os
# Set workspace (where all the KMLs are)
arcpy.env.workspace = r'H:\My Drive\map of carbon projects\kmz'
# Set local variables and location for the consolidated file geodatabase
outLocation = r'H:\My Drive\map of carbon projects\shp'
MasterGDB = 'AllKMLLayers.gdb'
MasterGDBLocation = os.path.join(outLocation, MasterGDB)
# Create the master FileGeodatabase
arcpy.CreateFileGDB_management(outLocation, MasterGDB)
# Convert all KMZ and KML files found in the current workspace
for kmz in arcpy.ListFiles('*.KM*'):
print("CONVERTING: {0}".format(os.path.join(arcpy.env.workspace, kmz)))
arcpy.KMLToLayer_conversion(kmz, outLocation)
# Change the workspace to fGDB location
arcpy.env.workspace = outLocation
# Loop through all the FileGeodatabases within the workspace
wks = arcpy.ListWorkspaces('*', 'FileGDB')
# Skip the Master GDB
wks.remove(MasterGDBLocation)
for fgdb in wks:
# Change the workspace to the current FileGeodatabase
arcpy.env.workspace = fgdb
# For every Featureclass inside, copy it to the Master and use the name from the original fGDB
featureClasses = arcpy.ListFeatureClasses('*', '', 'Placemarks')
for fc in featureClasses:
print("COPYING: {0} FROM: {1}".format(fc, fgdb))
fcCopy = os.path.join(fgdb, 'Placemarks', fc)
arcpy.FeatureClassToFeatureClass_conversion(fcCopy, MasterGDBLocation, fgdb[fgdb.rfind(os.sep) + 1:-4])
