Hello Esri Community, It seems like Arcade is a good option to use in this scenario below:
1. Currently, I have water lines that end at a valve point
2. I'm looking for a way in Arcade to insert a 2ft Service Lateral from those valve points on the downstream side. (opposite side of existing water line that terminate at valve / the clear side)
3. Once Arcade inserts the newly generated 2ft laterals after the valve points, then add a plug to the end point of the new lateral lines.
Is anyone familiar with how to accomplish the above using an Arcade Attribute Rule in ArcGIS Pro 2.9.5?
Thank you for any feedback!
