I am not able to run Sharepackage tool from a standalone script.(unable to sign in to portal)
Basically, It is not able to connect to portal.Just to clarify I able to run this script as Model Builder.
Also I am able to connect to portal via arcgis pro.
Error:
Processing .... Share Package :
File "e:\script\test.py", line 130, in <module>
arcpy.management.SharePackage(in_package=Maps_vtpk, username=_username, password=_password, summary=_summary_shrPk, tags=_tags_shrPk, credits=_credits, public=_public, groups=[], organization=_organization, publish_web_layer=_publish_web_layer, portal_folder=_portal_folder)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 12777, in SharePackage
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 12774, in SharePackage
retval = convertArcObjectToPythonObject(gp.SharePackage_management(*gp_fixargs((in_package, username, password, summary, tags, credits, public, groups, organization, publish_web_layer, portal_folder), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 002119: Must be connected and signed into the portal.
Failed to execute (SharePackage).
