I have a custom application in AppStudio that uses the MapViewer template to display a secured webmap retrieved from the client's Enterprise portal.
I want the user to start my map viewer template application and be able to view the map and layers without logging in. Instead, I have a portal token that is generated elsewhere in my custom application that I would like to authenticate the user with.
But in my research, I've not found a way to authenticate with anything but oAuth. Here's how far I got:
In SignInPage.qml (located in views directory), there is the authenticationChallenge signal that gets called from AuthenticationController.qml (located in views/Controller directory). The challenge parameter that gets passed in (AuthenticationChallenge) has a Enums.AuthenticationChallengeType value of Enums.AuthenticationChallengeTypeOAuth.
The specific question that I have is this:
Is there any way to trigger this authentication challenge with a different challenge type than OAuth? Like Enums.AuthenticationChallengeTypeUsernamePassword ? Perhaps, I could start with authenticating using username/password and then move on to portal token authentication.
TLDR: I want to authenticate a secured map from Portal in MapViewer without requiring my users to log in. I would like to authenticate using pre-generated portal token instead of authenticating on the spot with OAuth which requires the user to log in.
