Is it possible to set up a filter on a field with domains? We have a project that involves multiple agencies - the main agency should have full access to everything, and no matter how many times we try to communicate to other agencies, they choose domains they are not supposed to.
For better context, Agency 1 has full access to a list of statuses and the authorization to select 1-7. Agency 2 is ONLY supposed to select Status 1, which will flag it for Agency 1 to take action and assign it the appropriate status. Each agency has their own map and access to fields is limited in the form for each map, so it can feed the same database with some controls on what data can be edited by each.
It would be awesome if we could set filters up by map to limit domain choices. I realize this could probably be set up with contingent values before publishing, however, as projects evolve sometimes that contingent value link gets outdated.
Is this possible?
