Hi, I am working on a custom widget that will be used in an experience created with the Foldable template and 2 sources for the map widget (a webmap and a webscene of my area). Of course, it is very easy to switch views using the switch map tool that appears "magically" at the bottom left, but I would like to code the view switch in the widget. Right now, when I want to perform the switch, I know how to determine if the active view is 2d or 3d. I tried to change the state of my active view
