I'm trying to fine tune the Address Data Management template from the local gov solutions. I really like the ability to create both address points and site address points at the same time while using the "Add Site Address Point" tool. Is there a way to place the address point at the actual driveway cut, or along the curb at the center of a vacant lot instead of right on the centerline feature? If I try doing this the tool only creates an address point that has no attributes, the Attribute Assistant doesn't fill any of the fields for the address point and it doesn't create a site address point.
I am assuming this is something in the code for the Add Site Address Point tool. Is it possible to modify this code?
Jeff
