I'm creating a Python toolbox in ArcGIS Pro that will start an edit session on a layer in the map. In order to create the edit session, a workspace is needed. How can I derive the workspace from a layer in the map to use for the edit session? Nothing in Layer properties or Describe seems to work.
Since the layer is in an enterprise geodatabase (Oracle), the only solution I see right now is to get the connection_info from the layer object's connectionProperties and create a new sde connection file in a temp folder. I'm hoping there's a better way.
