I am trying to setup a StreamLayer with a custom WebSocket url, using Azure WebPubSub.
using the simple constructor as seen below:
const streamLayer = new StreamLayer({
popupTemplate: {
content: "OBJECTID={OBJECTID}, TRACKID={TRACKID}",
webSocketUrl: "wss://stream-layer.webpubsub.azure.com/client/hubs/SomeHub?access_token=xyz",
objectIdField: "OBJECTID",
fields: [
alias: "ObjectId",
type: "oid",
alias: "TrackId",
type: "oid",
timeInfo: {
trackIdField: "TRACKID",
geometryType: "point",
maxReconnectionAttempts: 100,
maxReconnectionInterval: 10,
renderer: {
type: "simple",
symbol: {
type: "simple-marker",
color: "gray",
map.add(streamLayer);
Azure WebPubSub requires an access token to be added as a query string to the end of the websocket url.
For some reason when trying use the websocket url on StreamLayer, it seems to remove the query string from the end of the websocket url?
So you end up with: wss://stream-layer.webpubsub.azure.com/client/hubs/SomeHub
