I have a map that I have created and uploaded to AGOL that will have an office user input for the first third of the fields in a given layer. I created a survey123 form from the existing feature service of the map that was created, and when I try to submit a response on the web app, it fails to send and gives me this error:
Failed to submit.
- - String or binary data would be truncated in table 'db_51652.user_51652.PORTLAND_LEAK_MAP_2023_WFL1_GAS_LEAK', column 'LeakID'. Truncated value: '{E5CE8770-69B7-455C-'. The statement has been terminated
In the map side, I have a GlobalID, and I have a text field called LeakID. It almost looks like when I try to send a survey, it is for some reason trying to put the GlobalID in the LeakID field. The leakID column only has a field length of 20, so I would understand why I am getting the error, but I don't understand why the survey is trying to put a value in for LeakID anyhow. Can anyone tell me what is going on here? This seemed like it would be a pretty easy process, but I have been fighting with this for a while now.
Damon
