I was running through the Watershed GeoInquiry in AGOL and the Create Watershed and Trace Downstream tools no longer work in Classic Map Viewer. Everything runs as normal, but the Adjusted Points and Watershed feature layers no longer show anything, essentially, there are no results. I have tested this in two different organizations with the same result. This is quite frustrating as I was planning on using these tools with my students. I could not find any similar posts with answers. I hope this is a simple fix.
Thank you,
Josh
