Hello!
I've downloaded a large number of MODIS (MOD08_E3) raster files. I am looking to export them to a geodatabase, rename them, build an attribute table, add a field and then calculate that new field. I've attached screenshots of my code in it's current form.
I have two scripts as I am working from two different workspaces - one where the files are originally held and then the second workspace is the gdb where I want to do further processing. I'm new to python/coding - would it be possible to obtain some advice on how to combine the two into one script please?
Thank you!
Posting pictures of code isn't much better than giving someone a picture of money, i.e., you aren't going to get much of anything for it. See Posting code with Syntax Highlighting on GeoNet and Code Formatting... the basics++ . Also, elaborate a bit more on what specifically isn't working. If you are getting errors, share the specific error and tracebacks.
Hi, thanks for the info - will resubmit
