I'm trying to create a calculated expression to populate a value in one of my fields. The expression gets the address of a feature that's within 100 feet of the feature the user is adding. If the expression doesn't get an address I want it to do the same process but with a different layer. I'm using literal strings in Arcade to populate the field. Can I not use multiple literal strings in the expression? Below is my Arcade expression.
if (IsEmpty(Geometry($feature))){
return null
var case = FeatureSetByName($map,"Active Container Related SRs")
var bufferedLocation = Buffer($feature, 100, "feet")
var candidateParcels = Intersects(case, bufferedLocation)
var featuresWithDistances = []
for (var f in candidateParcels){
Push(featuresWithDistances,
"distance": Distance($feature, f, "feet"),
"feature": f
function sortByDistance(a,b){
return a["distance"] - b["distance"]
var sorted = Sort(featuresWithDistances, sortByDistance)
var closestFeatureWithDistance = First(sorted)
if (IsEmpty(closestFeatureWithDistance)){
// return null
var rcase = FeatureSetByName($map,"Active Recycling Container Related SRs")
var rParcels = Intersects(rcase, bufferedLocation)
var recycle = []
for (var i in rParcels){
Push(recycle,
"distance": Distance($feature, i, "feet"),
"feature": i
return `${recycle["feature"]["IncidentAddress"]}`
return `${closestFeatureWithDistance["feature"]["IncidentAddress"]}`
