I have two Vector layers of lines. I am trying to find all the lines that are with in a set range of up to 200 meters, from one layer and are Perpendicular to the lines from the other layer (angles from 70-110 degrees). The Idea is to be able to sort the relevant lines by distance and angles.
Unfortunately I am not familiar with coding, if there is a solution that involves coding I will need guidance for it. All help is greatly appreciated.
Thank you, Peter
